Author Topic: centered artwork  (Read 4832 times)
ksvane
I'd like it if all non-square artwork (e.g. dvd or longbox covers) was centered in the artwork column instead of aligned to the left (as shown above.)
ksvane
Blinghound
Sorry to bring up an old thread, but has this been introduced yet? it doesn't seem to be the case with 1.2.4185
Cheers  :)
it should be - can you do a screen shot
Blinghound
Sure thing :), it looks like its when the fields are to the right, below works fine.
ksvane
does it by any chance make a difference whether or not the album info is below the artwork (as in mine) or on the right side (as in Blinghound's)?
it was intentional that the artwork isnt centred when the tag details are displayed to the right as i thought it wouldnt look as good.
i'm 50/50 about this though
ksvane
Blinghound, a slightly unrelated question for you... what software do you use to rip audio from dvds? :)
Blinghound
@Ksvane
To be honest, those are the only DVDs (in screenshot) I have in audio form, but DVD shrink + format factory works well, what about you?
ksvane
Been using something called DVD Audio Extractor which does the job perfectly but it's not free so I was hoping to find some great alternative :) I also have Magic DVD ripper but it only extracts to mp3 256 kbps or lower.
Blinghound
Handbrake is another good one - I used to use it a lot on mac, and it outputs to a number of audio formats. That's probably our best bet  ;)
