I'm having a problem. None of the presets are showing in the dropdown list for the equalizer. The .sde files are in C:\Program Files (x86)\MusicBee\Equaliser. This is where they were installed since I haven't touched anything. The only two items in the dropdown list are Manual and Auto-Select by Genre.
Shouldn't all the presets be listed?
I am using the installer version of MusicBee 3.4.8033 which I downloaded from the MusicBee website.
Any ideas what I am doing wrong? I couldn't find any kind of setting that would impact this.
I originally posted this in another topic which was labeled as "Solved", so I thought I should break it out into its own topic. Sorry if that was incorrect.
Thanks,
Bill
