Author Topic: "The library cannot be changed while background tasks are running."  (Read 833 times)
morgan109
Not sure this is a bug but what the heck is this?
I literally can't change my library!
A background task is running. If you don't know which one it is, reboot your PC and then open MB. At that point you should be able to change your library.
morgan109
Ok a bit strange it happens nearly always but at least I now know it's outside the programs control.
I'm curious - how many libraries do you have? And why?
If set up each one as a filter you wouldn't have to keep changing libraries.
https://musicbee.fandom.com/wiki/Filters
