Author Topic: Previous Track stops playing 1st track if less than 20s  (Read 894 times)
Benke
Previous Track stops playing 1st track, even if repeat is enabled.
This only happends if the song has been played less than 20s. After 20s it restarts the track as expected. I can't see Stop playing would be a logical action in this scenario if repeat is also enabled.
For a guitar player who regularly restarts a song when learning how to play the intro it can be quite annoying. :(
Thanks for developing the best audio app!  :-*
If this is an important feature for you to have, you could do this:
Make sure that 'stop' and 'play' have dedicated shortcuts.
Create a simple script for AutoHotkey that first presses the hotkey for 'stop', and then the one for 'play'.
Asign a hotkey combination for that script (that is not in use for MusicBee) and you're set to go.
