Author Topic: Send To: Copy to Organised Folder  (Read 2447 times)
ost
Hi! Just noticed a few days ago when I hit "Send To: Copy to Organised Folder" to move selected audio files it's also moves cover art files (Cover.jpg). Before it moved only audio files.
by 'move' i assume you mean 'copy' - correct?
in that case that is the expected behaviour - nothing has been changed
Last Edit: December 29, 2021, 08:20:18 PM by Steven
Jaslan
There is an option to also move remaining non-media files.  Perhaps you didn't have it checked before?
You're confusing us. You say "Send to: Copy to Organized Folder" but then you say "to move selected audio files."
Which are you trying to do? Copy? Or Move?
It makes a difference. And without clarification, we don't know how to help you.
ost
Sorry - yes, I mean COPY files not move.
Thanks for the clarification.
"Send to > MOVE to organized folder" has an option to also move non-media files.
"Send to > COPY to organized folder" does not have that option. And as far as I can recall, it never did.
ost
In my case it did - version 3.4.8033. It copies audio files and non-audio files (cover.jpg)
Yes, that's correct.
When copying, the non-media files are also copied.
When moving, there is an option to move or not move the non-media files.
And as Steven said, this behavior hasn't been changed.
ost
Is it possible to made a change and be able to choose when copying not copy the non-media files?
You'd have to put this on the wishlist for possible consideration.
Also - since this is not a bug, I moved the thread to the questions section.
