Author Topic: Support for non-square album cover arts  (Read 7465 times)
lightningrod
I found an unpleasant aspect in MusicBee: it supports album cover arts in SQUARE ONLY, and streches them to square if they are not, quite the same as the stupid Windows Media Player does.
So my point is - and I think it's easy to achieve - to ask for support for non-square album cover arts in MusicBee.
Thank you ;)
Last Edit: July 12, 2009, 08:19:38 AM by lightningrod
which version of musicbee are you using? i thought i fixed that quite a while ago! would you mind trying the 1.1 version - this is the latest link:
http://www.mediafire.com/?ajknnq5imm4
just copy the files to your musicbee program folder and replace the existing ones
lightningrod
Thank you for your fast reply, I was using MusicBee 1.0 RC2 because that was from "Download" section in your homepage.
I have just upgraded to version 1.1.3480 and I found the problem has been partially resolved.
Please check the screenshot: http://lpj31w.bay.livefilestore.com/y1pXENNb0lAh1QAVBGC1Uxon-LgYXVm9-tJbsoqPQ7W0buAz48X0X1s8r-z2jDYDf2a_ngukXnIO0_0q1FAFJ0k2PeiVam3Omso/musicbee.JPG
Besides, I live in China and China has blocked access to mediafire, I have to use Proxy to download the software. So I'm wondering if it's too much to ask for another download option such as the SkyDrive. Hope it won't bother, please ignore this if it does.
ok, i can see i need to also fix the stetching in the album view and will do so - I'm posting a 1.1 beta update later tonight.
just regarding skydrive, i had a quick look and seems ok so i can add that as a secondary choice
lightningrod
WOW, you are really an amazingly excellent software developer! :D
Thanks a million times for adding SkyDrive as a secondary option! :-*
i've uploaded the latest 1.1 beta to skydrive which includes this fix
https://cid-9847a1cf4086fc03.skydrive.live.com/browse.aspx/MusicBee%20Beta
the releases notes are on the 1.1 beta topic
when i do the next full update of musicbee on the downloads page i will also include that on skydrive
lightningrod
 :D All cover arts are displayed normally now! And another tiny issue resolved! (Can't drag and drop in Album Layout which I discovered later)
Thank you again for making skydrive an additional download option! :D :D
