Author Topic: Enable Reverse Tempo Along Tempo Continuum  (Read 2869 times)
eeik
Using the tempo +/- 10% hot keys could be enabled with a lower end to the existing continuum that fully reversed the playback. At the current floor, -50% tempo, the next hotkey would flip the tempo backwards with playback at "negative 0.5x playback speed". See the illustration below as an example of what I had in mind.
Extending the lower floor down to "negative 1x playback speed" would be a good place to start with the feature if you opt to implement 🤞
Example Screenshot
mrbenn
Although very niche, some sort of transport/pitch control would have its uses.
It takes a minute to load a daw or something like audition or serato to just play it backwards, or see what it sounds like at some random pitch.
