Author Topic: Auto-playlist export  (Read 1871 times)
NAWTBOY
Do you have to exit out of the program in order for the auto-update of the playlists to export?  I have my playlists going to a folder i have set up on Dropbox synced to another computer.  It only seems to update when I close the program.  I'm wondering if there's a way to increase the frequency of it updating without having to close the program.  I will sometimes set up a playlist on my desktop that I want to sync to my laptop but I forget to close the program and the updates never make it to the laptop.
  • Heal The World
Opening the playlist's settings and then clicking save should make the update you're referring to.
Strength and Honour (2025)
