What version of MB are you using? (Help > About)How was MB installed? (Store, Installer, Portable)
I'm on 3.4.7966 P. Installed portably.
Quote from: SonicRings on December 01, 2021, 03:39:49 AMI'm on 3.4.7966 P. Installed portably.I can't recall anything changing along these lines recently, but it wouldn't hurt to update to the latest patch. See my signature.
Sure, can you tell me the version number that yours is before I install it?
This should fix the issue:https://getmusicbee.com/patches/MusicBee34_Patched.zipunzip and replace the existing musicbee application files
i wont be able to help any further with this as its working fine for me after the fix.If its updating the library sorting then that means you are not updating a custom field playlist
