Author Topic: Sorting playlists individually seems to have stopped working?  (Read 3702 times)
SonicRings
I don't remember ever having this issue before: when I change the sort order of a playlist, it changes the sort order of all playlists.
I referred to this thread to no avail: https://getmusicbee.com/forum/index.php?topic=25519.0
My playlist settings is as so:
However, changing from manual sort order to this changes it for every playlist:
As seen here:
And, changing it back to manual order here:
Changes it back to manual order on the first one:
SonicRings
Ah shoot, sorry about that, I usually remember to include that info.
I'm on 3.4.7966 P. Installed portably.
I can't recall anything changing along these lines recently, but it wouldn't hurt to update to the latest patch.  See my signature.
SonicRings
Sure, can you tell me the version number that yours is before I install it?
I can reproduce the issue for the Album Covers view so i guess its a bug that i will look to fix.
As long as each playlist is configured for custom fields, then the Track Details and Album & Tracks view works as expected
3.4.8001, but the latest patch may be a higher version number since I patched two or three days ago.
But as Steven says, it's a bug and he'll looking into fixing it.
SonicRings
Apologies for not responding: I had intended to do so then I got these messages but I was having trouble on my phone.
Anyway, good to know it's reproducible. I'm looking forward to the patch!
SonicRings
This should fix the issue:
Thanks Steven. I just installed this patch but I'm experiencing the same issue. I don't think this fixed it unfortunately. Changing the sort order still changes the sorting for other playlists, as well as the sorting for my library itself.
Last Edit: December 07, 2021, 10:38:12 AM by SonicRings
i wont be able to help any further with this as its working fine for me after the fix.
If its updating the library sorting then that means you are not updating a custom field playlist
Last Edit: December 07, 2021, 11:00:31 AM by Steven
SonicRings
Ah, you're right. Somehow the playlist got set back to "use default". Setting it back to custom fixed it. Much appreciated!
