Author Topic: MusicBee Start Menu Tile  (Read 8942 times)
mvana
Windows 10 Start Menu Shortcut Tile for MusicBee
Download page
Icon source: BallBee App Icon & Tiles for Win8/10
Instructions:
if MusicBee was installed in default directory, then put the content of the "Tile.zip" inside of- C:\Program Files (x86)\MusicBee\
If you're using Windows Store version of MusicBee then it's not going to work.
If you want to change the name of the png then edit MusicBee.VisualElementsManifest.xml
Last Edit: November 27, 2021, 02:19:02 PM by mvana
