Author Topic: Dark bitmap skin (old version)  (Read 18568 times)
Thank you, I've just tried it, still not working.
I think it is because of a typo (and a discrepancy) you have at: "Panel.HeaderButtonOverride.Default"
For fg it has:  Hightlight-Text
But the variable is:  HighlightText
mvana
The elements above do, so another element somewhere in your skin must be overriding the default color.
Search your skin file for "Override." If you don't have any of those elements, you'll probably need to search "CaptionBar" line-by-line and change any element that looks like a match to a stand-out color.
Still couldn't find anything, but when I right click > configure toolbar > Show buttons in a separate bar > then it shows the color but in goes on top bar with the search bar
mvana
Thanks, I fixed it but still not working
Are you sure you fixed both the typo (Hightlight) and removed the dash?
mvana
