Author Topic: Musicbee overlaps my taskbar  (Read 3284 times)
MusicMovesMySoul
Hi there,
So this never happened before & a couple of months ago it started to be a problem. I can't gain access to the rest of my computer because it's overlapping my taskbar.
I'm on Win 7 & using Classic shell, but we did some troubleshooting & nothing has helped.
1. Changed the Theme to Win 7
2. Exited off f.lux
3. Maximize, minimize, Ctrl up & down
4. Windows key & up/down arrow
Nothing has worked.
Can you fix it, please?
Thanks
You could reduce the MB window a little to expose the taskbar.
You could try setting the taskbar to auto hide.
A screenshot might also help here.
MusicMovesMySoul
Sorry, I knew something was missing from my original post LOL
I just installed the latest version 3.4.7805 from the site, same issue.
Here's a SS - https://i.imgur.com/98luFCA.png
I want a permanent solution, plus it never used to do this before.
Also, is there a way to save a file of settings b/c I'm about to reformat & I don't want to have to redo all of the hotkeys.
Thanks
I dont have windows 7 any more and wont be able to help. I dont recall this issue ever been reported before so my suggestion is simply dont use MB maximised ie. resize the window to the maximum size manually
Settings:
Panel layout:
MusicMovesMySoul
Settings:
Thank you. I already reformatted.
Panel layout:
MusicMovesMySoul
No, it never did do that until a month or two ago.
Even after my reformat it is still having the same issue.
Thanks
