Author Topic: Right sidebar not displayed correctly when displayed using mouse hoover  (Read 4796 times)
DQ
Hi
I have a right sidebar with the tag editor, track information and lyrics.
When I show this using the small icon on the bottom right, it appears as it should.
When I set it to auto-hide and I open it by moving my mouse cursor to the right, I miss the title bars for the top two items and I see a partial picture at the bottom. (there shouldn't be any picture there)
Using MusicBee 3.4.7805 on Win10
Correct display: https://www.mediafire.com/view/b6hq7qalbau2erd/B2-Correct.png/file
Incorrect display: https://www.mediafire.com/view/arqhp6jt0xjuo8m/B2-Error.png/file
  • MB Version: 3.6.9255 P
Please update to the latest patch to see if that effects your problem.
DQ
Thanks for the update.
The superfluous partial artwork at the bottom is gone, but the header bars for the tag editor and the track info are still missing.
Two things I noticed and that might give you a clue:
1) If I click on the location of the missing Playing/Selected button for the track info, the panel actually switches but only on the first click. If I click a second time it doesn't work anymore.
2) If I right-click on the location of the header the popup menu appears, but it appears on the left side of the screen instead of the right side where it should.
It also does this if I click on the header of the lyrics (although that one is visible) The other popup menus (on the artwork or lyrics...) all appear on the correct location. So only that of the headers is misplaced.
i cant reproduce any issue but you are using a custom tab layout: MusicManager.tab-layout in AppData\Saved Settings\Layouts
could you also send that to me
DQ
I wasn't even aware that I saved a custom layout (I've done a lot of experimenting since I installed MusicBee).
Here is the Link
i can reproduce this now using your custom layout so should be able to solve the issue
DQ
That's great news.
I would also love to hear what is so special about my layout that it causes this bug.
DQ
