Would it be possible to add an adjustment parameter concerning the volume ...
could it be possible that the volume of the MusicBee application matches that of the Windows System (same in the other direction.)
(When we adjust the Volume of MusicBee, the volume adjusted and displayed in MusicBee is that of windows)
https://i.imgur.com/piVZOuw.jpgexample =
- if the user increases or decreases the volume of the MusicBee application, the system volume is modified and displayed in the MusicBee interface.
- Same in the reverse case; the user increases or decreases the volume of Windows System = the volume of the MusicBee application is changed (and displayed in the MusicBee interface).
Why this request:
We use a remote control (infra-red) on the PC (computer).
By using the remote control to adjust the volume and at times the volume displayed on the MusicBee application screen.
The volume is very low when using the remote control and the display several times.
This requires checking the two Volumes (that of MusicBee and that of the windows system)
and then the remote control becomes useless
if we have to move to increase the volume displayed on the screen of the MusicBee application.
Thank you for your software which is TOP
(sorry for my bad English
