Author Topic: Search bar issue.  (Read 3987 times)
Franx
Recently, I encountered an issue with the 'search' bar. It just stopped searching. The main panel would flicker, but the listing would remain the same. I persevered, checking this, changing that, but to no avail. In the end, I uninstalled Musicbee 3.4.7805 and downloaded it again. Problem solved. Has anyone else experienced such a glitch?
unless you are able to provide reproducible steps, i wont be able to help. I dont recall anyone ever raising this issue before so it must be something very specific you were doing
