Author Topic: Total Artist Play Count as a Virtual Tag?  (Read 8198 times)
The Incredible Boom Boom
Ok, weird...
Maybe I just don't understand how these are supposed to work...
@Steven, inside a Virtual Tag, the provided function examples work, but when used in the Track Information panel, all of them, except $Sum(<Play Count>,<Artist>), just display zero.
Halp!
its a bug but for now if you assign the formula to a virtual tag it will work
edit:
this should fix the issue:
Last Edit: October 16, 2021, 07:30:25 AM by Steven
edit:
Dope! It's working. Thanks for the quick turn around.
Now to think of different use combinations.
Using a function inside the second argument of either $Sum() or $Count() in the Track Information panels returns garbage values and clears sets the argument to <>.
For example, $Sum(<Play Count>,$Split(<Sort Artist>,;,1)) results in $Sum(<Play Count>,<>) and a random garbage value as the result.
