Author Topic: Not Working And No Help Whatsoever!  (Read 7289 times)
Annie Body
I have posted twice previously asking for configuration help but have never received a reply.
My last post concerned the failure of the latest Remote Plugin 1.4.1 to not provide a working install button. It appears that someone, possibly the Big Brother administrator, doesn't like to hear bad news and removed it!
I am now left with MusicBee that does not work the way I would like, that is in a similar way to other music apps, and with no ability to use it to stream music, the main reason for installing it.
I can only assume that the program is not supported and clearly the developers do not want to promote it.
What a shame I have no choice but to seek another app that is supported and works.
The post is still present in the plugin thread. The plugin developer replied to you in that thread but you never answered his questions.
Annie Body
If as you state, the plugin developer replied, then please explain why checking the reply options does not work!
I'm not sure what you mean, but here's the post: https://getmusicbee.com/forum/index.php?topic=7221.msg193727#msg193727
Annie Body
According to my account profile the post claimed to have been responded to does not exist!
So which of these is the problem:
1. The account is now working?
2. The reply notice is not working?
3. There is no way to find the original post nor the reply?
4. Issue with user.
Annie Body
The link provided by 'psycoadept'  only goes to prove my point!
How am I possibly going to find this reference when I no longer have any way of accessing the original post.
Also, the claim against the link is that I have 6 posts. So where are they? My understanding of maths is that the value of 2 posts in my account is not the same as the value of 6 provided by the link.
Also, if you follow the link and its apparently random entries, I can find no response to my question.
Normally forums display the response. So when you claim to have answered the question please list the answer so that everyone can read it!
Using the link psychoadept provided, I simply scrolled down until I found this:
Your question still exists and it has been replied to.
Annie Body
'hiccup' Thanks for your response.
It proves I am making the right decision by looking for a well written, documented and supported alternative.
As your reply clearly demonstrates when a user has a problem sarcasm is the only response you can expect!
I wish you luck with the program, as with this attitude you are going to need it!
I'm the moderator that MOVED your original post. I did NOT REmove it. I moved it to the thread belonging to the plugin you're having issues with. When a thread is moved (or merged) you receive(d) an email with a link to the new location. Apparently you didn't check your email.
https://getmusicbee.com/forum/index.php?topic=7221.msg193712#msg193712
Annie Body
'phred'
The link is on page 46 of 47. There are only 11 follow up posts none of which provide an answer. Where are you looking?
You are welcome.
I am glad I was of help for you to make the decision to move along.
'phred'
And did you read the follow-up replies?
You have to scroll through them. Reply #682
