Author Topic: When Next song is played previous songs are removed from playlist.  (Read 1516 times)
user73
Hi
As the title suggest only the song that is played remains on top in playlist and before that all are removed automatically. I am sure i haven't changed any setting at all.Suddenly it has started happening.So i have 50 songs in playlist and i click on 20th songs,then 20th songs will start to play and above that all are remove from playlist.
thx in advance
user73
thx for replying steven..I am pretty sure i didn't change anything in MB for few months.Just listen for a while and exits.But still how it can be switched to normal mode?I have 3-4 tabs and all have same problem.Only NOW PLAYING is working find which i don't use.
user73
