Author Topic: No Artist or Album  (Read 1180 times)
Lincoln
All of a sudden,  I can't really control MusicBee.
I can't get to Albums, and I'm not sure how to get into Artists. It happens sometimes.
Sometimes I get album photos when I just want a list of songs.
Some playlists that have specific order of songs.
The playlists seem to be always on shuffle, even though shuffle is turned off.
How do I fix this?
Lincoln
At a guess,  it sounds like you may have hidden the menu to select the different views.
Try right-clicking the empty space under the tabs row (i.e the red area in this screenshot):
The context menu will let you change between views, or you can check Show Header Menu to always the display the drop-down menu:
I think the default shortcut keys to change between the same views are Ctrl+1 through Ctrl+4.
If this is isn't what you meant, I think you'll need to include some screenshots to explain your problem because your question is a bit vague.
