This is a problem with your data, not something that MusicBee should be reprogrammed to compensate for.
No, it is possible for an artist to record the same song, but the song has a different sound to it. (please see example below).
But it's not one.
Yes they are different
Please check these two links out:
https://www.youtube.com/watch?v=fxU2PvkPi9Mhttps://www.youtube.com/watch?v=CYMu7f5_8rEIf I download both these songs and run a musicbee rename/relabel, they are both "Steve Void, Strange Fruits Music, Koosen - Blue (Da Ba Dee)"
one of them is 2:00 and the other is 2:12, similar but different.
I am saying/asking; I want these two songs not to be identified as being the same song.
This is just one example of many songs that I have, that are similar but different that musicbee is falsely categorising as a duplicate.
The way I have distinguished these songs is by using the "<Artist>\<Artist> - <Title> - <Time>". I am asking that MusicBee's "Duplicate manager" have options to determine which fields are used to classify a song as a duplicate. (aka I could use fields "Artist", "Title" and "Time" to determine if a song is a duplicate or not, rather than musicbee's default of "Artist" and "Title").
That's silly. It's incorrect information. Correct the incorrect information and you fix your problem. What is going on here?
I have renamed the files of the songs to be "<Artist>\<Artist> - <Title> - <Time>" which makes them unique, they have the same artist and title but are different songs. They have the same artist and the same songname.
I can think of two potential solutions to this:
A) songs are only classified as duplicates if they are "Filename", "Filename_1", "Filename_2", etc
So as long as the filenames are unique, then the songs are also classified as unique.
B) MusicBee's "Duplicate manager" have options to determine which fields are used to classify a song as a duplicate.
C) musicbee generates a list that has all the duplicates within it, so the user can organise them.
My real question I was originally trying to ask is "how does musicbee determine if a song is a duplicate or not?" I had assumed it was based on filename (hence-wise why I renamed files to be "<Artist>\<Artist> - <Title> - <Time>".) If i know how musicbee determines songs are duplicates, then I might be able to manipulate my duplicated songs in a way that the programs classifies them as different songs.
