flaws:
1. When no library panel icons are supplied with a skin, IconColourOverride.Default doesn't affect OpticalDriveIcon.
2. IconColourOverride.Default blanks the Songkick image in the upcoming concerts panel.
3. Controls.SliderBar.Disabled does not work on the sliderbar in the auto-dj panel (selection mode)
4a. In Panels Configuration, you can drag the Sidebar Player element to the Top and Bottom Panel.
That won't get applied though, so these positions should probably not be allowed to drag to in the first place.
4b. You can also drag to it the Floating Panel, but I am guessing that's not intended, since it's a bit weird as a floating panel.
5. When a certain amount of elements is dragged to the left side of the Panels Configuration panel the Save/Close buttons become unavailable.
6. Some text in the Playing Tracks panel when using Album and Tracks has an extremely low contrast.
(using <element id="ContrastBoost" doesn't improve it either)
requests:
7. When no love icons are supplied with a skin, a hard coded reddish love icon is used. A colour override for it would be nice.
8. When the player is stopped, Player.SpectrumVisualiser displays all the bars, taking (mainly) the colour of fg2.
That looks ugly and a bit convulted when fg2 has a higher contrast value.
Either having it using bg instead, or having a dedicated element would be nice.
9. The searchbar in the now playing panel takes its background from Controls.InputControl.Default
It might be better if it used Panel.SearchBox.NotActivated
10. In a skin xml file, you can add comments by using <!-- … -->
It will work in the <colours and <settings trees, but if you do it in the <variables tree it breaks the skin.
If possible it would be nice if comments could be added there too.
