Author Topic: Can't Change Column Widths in Autotagger Dialog Box  (Read 2033 times)
denzoid
Title pretty much says it. This has always been an issue for me. How can I change these columns' widths?
https://www.mediafire.com/view/emh6ws0h05e7ydv/auto_tagger_columns.JPG
Hover the cursor over the column separator in the headers. When you see the double-headed arrow right-click and move it.
denzoid
Ummm yeah...I tried that...(didn't think I needed to mention it) ..the columns just don't resize/change at all.
Obviously you did need to mention it as it's the only way to resize those columns.
denzoid
Running version 3.4.7805, first installed it via downloaded installer.
for some reason i locked the width of the track number column, so i will make it expandable for the next patch update. You should be able to adjust other columns though
denzoid
Yes, I can adjust the other columns, just not the track column. Thanks for the help, much appreciated!
denzoid
That fixed the issue, I can see the track numbers now. Thanks for the super quick fix!
