Author Topic: "Play count +1: more than 50% of track played or x seconds"  (Read 1065 times)
Frunk
Hi there,
I have set my Preferences > Now Playing > Playback > Play count +1 to "more than 50% of track played or 240 seconds", however, songs only appear to receive their +1 when (and if) they are fully played through. I tried changing the 240 seconds setting to 0, but nothing appeared to change.
Am I doing something wrong? Is there another setting to increase the play count when at least half the song has been played, and/or am I misunderstanding the purpose of this setting?
Thanks in advance!
The Incredible Boom Boom
...however, songs only appear to receive their +1 when (and if) they are fully played through.
If you have <Play Count> (or whatever the tag is) on a Main Panel, you won't see it visually update until the end of the track, but if you stop the track after half of it or more has been played, it will update the count.
Frunk
Ah, I see. As simple as that. Yep, tested that out and indeed that is how it works. Thanks very much The Incredible Boom Boom.
