Author Topic: Kryptonite Dark  (Read 11116 times)
Ingo_Igel
I started this little project for myself, but it turned out so well that I wanted to share it with you.
This theme is based on the Windows 10 dark theme colours and a touch of Winamp Classic.
--> Download v 1.1
Installation instructions:
Place the file in your Musicbee/Skins folder and select it in Musicbee by going to View > Skins.
Information: Changing the colour variables in the xml file will not change all the icon colours.
Known Bugs/Issues:
Update 1.1
- New entries added and obsolete entries removed to match MusicBee version 3.5.
- Restructured the entries to match the latest version of hiccup's sample skin for easier debugging.
Update 1.0
- New suitable "LargeTick" image
- New suitable "OpticalDriveIcon" image
- Cleand up code
Update 0.9.3
- New suitable "CheckTick" image
- New suitable "CheckTickDisabled" image
Update 0.9.2
- "Controls.ProgressBar" elements have been commented out.
Please feel free to leave comments and feedback.
ENJOY AND HAVE FUN!
Thanks to hiccup for his Sample Skin
Thanks to Muvikui for the no album art (CC-BY-SA 4.0)
Last Edit: March 26, 2024, 08:21:23 PM by Ingo_Igel
Thanks for sharing your work!
(and welcome to the forum)
Known Bugs/Issues:
- "IconColourOverride.Default" is overriding the colour of the chekmarks in the menus.
- If the Track Information is selected in the now playing bar at the bottom panel, I have no idea how to change the font colour.
- I don't know how I could test the three "Controls.ProgressBar" elements or where I find them in Musikbee.
1. If you want to override the checkmark, you need to use a 16x16px image file, encode it to base64, and copy it in your skin.xml under 'images' as  <element id="CheckTick">
   (a forum search should lead you to how that can be done)
    You will probably also want to define others such as "CheckTickDisabled", and "LargeTick". (for the Panel Configuration panel)
2. Over the years, the functionality of that panel has changed a little bit, and I am not completely sure how it is controlled at the moment, but far as I know the text colour is auto-generated depending on the background colour.
3. These are obsolete (as far as I know)
   If you check the paragraph at line #10 of my sample skin you can read my current understanding/handling of those.
Last Edit: July 13, 2021, 06:53:55 PM by hiccup
Ingo_Igel
Known Bugs/Issues:
Thank you for your help hiccup.
I added/deleted everything as mentioned.
IndigoFairyX
i love this skin. ive been trying to trying to edit it with my own color tweaks. im not a coder, this the first skin.xml ive everworked won. i keep breakting the buttons somehow. i think that more to do code bewteen  how the prefs panel & metadata panel & menu options relate to each other in the elements ids. but i dont really know either. i started a tread about it over here
Ingo_Igel
I'm glad you like the skin and I've seen that you've already solved your problem.
IndigoFairyX
 had to learn what i was doing. theres so many elements and settings in skinning that aren't easy to track down. and now i just noticed you did a big update too. i cant keep up.
i spent i think bout 3 weeks on tweaking this. its kept changing from that first screen shot. heres another. .. i also made two spins off with brighter text for those wanted it.
once i figured how how to make a gradient in the code i drove myself crazy with it almost everting got a gradient.
cheers! thanks for the inspiration! this is my first skin. likely my last! hahaha. it was kind of fun to learn thou.
Ingo_Igel
You only get better by practicing and learning, so keep going!
Maybe it will help if I roughly describe my workflow here.
First, I started with the Sample skin from hiccup as a basis and defined variables for the recurring colors. I used "Visual Studio Code" (free of charge) for the coding.
Then I used the "jcpicker" (also free of charge) to read the RGB code of the elements from the sample skin and searched for it in the Smaple Skin code. Sometimes you have to work a bit with the snipping tool to get the colors of elements that change color when hovering over them. This way I was able to assign the previously defined variables as colors to all elements piece by piece.
For the setting entries I searched for them here in the forum or google to find out what they do.
Finally, I use the comparison function in "Visual Studio Code" for debugging and comparison with the current sample skin version.
