Thanx, interesting reads. I was using the venc.exe encoder (6.03) from aoTuv, but maybe you can explain me the difference between the OggEnc2 and the Venc encoder. Is it the SSE2 optimalization?
When it comes to SSE instructions, updating encoder to a newer version of the compilation is not always recommended. Generally, you should use a compilation optimized to the highest SSE instructions supported with your CPU.
If you have a very old single core processor, you shouldn't expect significant speed increase and much better quality after using a compilation of the encoder optimized for newer SSE instructions. Furthermore, using SSE4 optimized builds when the processor supports SSE2 instruction could even decrease the encoding speed as it was reported by a Hydrogenaudio forum user.
For an old processor that supports SSE2 only, the
Blacksword (Lancer) builds were recommended, but
some audible distortions have been reported recently.
Here is the info form the above mentioned Blacksword website, that could be helpful if you are not sure about SSE instructions supported with your CPU:
Lancer 20061110(Based on aotuv-b5_20061024) readme_j
SSE: AthlonXP (Barton core and older), Pentium III
SSE2: Athlon64, Opteron, Pentium IV, Pentium M
SSE2MT: Multi-threading version of SSE2
SSE3: Athlon64 Rev E (Venice & San Diego core), Pentium IV (Prescott core), Core Duo(Solo)
SSE3MT: Multi-threading version of SSE3 for Athlon64X2, Pentium D, Core Duo(Dual), Core2 Duo(Conroe & Merom core)
At the Hydrogenaudio forum you can find the opinion that SSE3 optimized builds can give better results for SSE2 compatible processors (and the above mentioned sound distortion is missing when proper SSE3 compilation is used).
For your SSE2 compatible processor, have a look at
this topic.
Recommended settings for OggEnc by Hydrogenaudio forum members are always posted
here.
I guess MusicBee predefined settings should be updated accordingly when an updated version of OggEnc is finally distributed with the installer.
I prefer aoTuV (Aoyumi's Tuned Vorbis) as it's continuously updated, and gives better quality results, especially when encoded to a lower bitrate level. You can find more detailed info at the proper section the Hydrogenaudio forum or maybe you should
try it out in person to hear the difference . The tunings done by Aoyumi are usually implemented to the next stable version of Xiphophorus libVorbis.
As you can read at the forum:
Venc doesn't support adding vorbis tags!
but if you should embed a very big Artwork into an ogg file some old portable devices won't read the file properly due to
lack of memory.
But if you encode your audio files for portable listening at lower bitrate, the Ogg Encoding gives significantly better quality than mp3 (LAME). Have a
look[/u].
I don't need to mention that properly encoded ogg files are much smaller than the same tracks encoded with mp3 (lame).
But i will give it a try, and if I find a difference i will report back.
Please, report your results. It could be helpful for others
