Author Topic: File Organiser options are suddenly all greyed out  (Read 1400 times)
asdasdasd223
Which file in Musicbee's folder controls File Organiser's settings? I'd like to reset it to default. Auto-organization still works properly with the rules I had before, but I can't change any of them anymore.
Please post a screenshot of the grayed-out options.
asdasdasd223
if you have auto-organise enabled in the Library preferences, and try to manually organise a file thats in your music library then the settings cannot be changed in the manual organisation dialog ie, you can only change the auto-organise rules in the library preferences
asdasdasd223
I wasn't trying to manually organize, I just like to use ctrl+r to go straight to the auto-organize settings. Any reason it's necessary to prevent change to the settings using ctrl+r? Is this a recent change or has it always been like this? Coulda sworn I used to be able to change it with that hotkey. But it's been probably been 6+ months since I had to edit those settings.
If I'm remembering wrong, could you please tell me what the hotkey is to go straight to the auto-organize settings rather than the manual organization window? I don't see it when searching in the hotkey settings. If there isn't one, could you add it to the next update please?
There is no default hotkey for auto-organize. As a matter of fact, there is no default action for auto-organize.
Go to hotkey preferences and search for organise. and you'll see the three available actions, two of which have default hotkeys.
Auto-organize can be enabled/disabled in Preferences > Library > music library. But again, there is no hotkey for it.
