Author Topic: How to change playlist Manual Order sorting?  (Read 2368 times)
Red_BY
New user here.
So I created a new playlist and added a bunch of albums. Right now they appear in order in which I added them, under Sort tab it appears as Manual Order. But I cannot find a way to change it. Drag and drop does nothing and there are no settings to change it. Can someone explain how can I reorder my albums? The only way I found it too add everything from scratch in order you want but that's just very inefficient.
At the upper-right of the main panel there's a drop-down menu where you choose the view for your playlist.  There are sorting options there.
If you want to save the new order permanently, right-click the playlist in the playlist explorer and select List->Update Play Order.  This will make the current sort the new "manual order."
Also, if you use tracks view, you can click any of the headers to sort by that field and then do the List->Update Play Order thing to save it.
Last Edit: June 12, 2021, 01:22:18 PM by frankz
