Author Topic: Artist field in player control panel is filled with an color  (Read 2408 times)
fournier
Like the attached image, artist field in player control panel is filled with an color.
It happens in the following situations:
  - As artist name is too long to be displayed in player control panel, the panel scrolls artist name.
  - Artist filed in player control panel is off-screen partially
I'm using MuiscBee 3.4.7805
fournier
i can only reproduce the 2nd issue. For the 1st, i dont recall anyone reporting that before and its something i would have expected to be reported by other users and fixed a long time ago. What is your screen dpi setting in the windows control panel system/display tab? eg. 100%
fournier
100%.
i can only reproduce the 2nd issue. For the 1st, ...
I reported only one issue that artist field is filled with an color as artist name is scrolled.
It happens only when artist name is long and the right side of MusicBee's window is overhanging the display
like this:
I'm sorry for my poor English.
What skin are you using?
I am guessing it only happens with that skin?
edit:
Never mind, so it isn't skin related.
It resembled a visual glitch that can occur with skinning and scrolling text.
Last Edit: June 12, 2021, 10:33:50 AM by hiccup
i see. So in that case i can reproduce the issue but dont have a solution as yet
edit:
this should fix the issue:
Last Edit: June 12, 2021, 08:17:19 AM by Steven
