Author Topic: Soundcloud Issue  (Read 17991 times)
Sorry, but Soundcloud is not available in Russia:
He never said he lives in Russia?
And he did say SoundCloud is available in his country.
If it's about Cyrillic in the screenshots:
"Cyrillic is used in several countries such as Belarus, Bulgaria, Macedonia, Montenegro, Serbia, Ukrainian, Uzbekistan, Kazakhstan, Kyrgyzstan, Russia, and more"
Moodymann
Most likely something is blocking access to the network. There is a similar problem with podcasts - they do not work
Moodymann
It still doesn't work. I go to the SC website in a regular browser without VPN. Maybe the program needs to open a special port or change the hosts file?? Search doesn't work with VPN either. I have Win 7 and maybe I need to patch it? At the same time, everything works on a laptop with Win 10.
Perhaps this is the issue.
Works fine with W11 also.  With Windows 7 I bet you need to add  TLS 1.1/2 like for so many other sites with Windows 7.  Save this as a *.reg file and double click to enter it into your registry.  A restart may or may not be needed (worked on my "final build" Win7 machine right away):
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.1\Client]
"DisabledByDefault"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.2\Client]
Moodymann
Awesome! You helped me a lot. Thank you very much. Now the search works!!
