Author Topic: Grouping by Folder AND sorting by filename  (Read 1556 times)
Ezhaac
Hello there =)
I feel like I'm gonna ask something rather basic but I've looked through the options, some forum posts as well as the wiki on grouping/sorting and I couldn't find what I'm looking for ^^
I'm not using tags or metadata for my music and I'd like to reproduce how VLC is sorting the files when I drag and drop folder into the playlist.
I'd like to sort them by folder AND within each folder: by file name.
Let's say I have these 2 albums from Ghinzu:
If I drag and drop the "Ghinzu" folder in VLC, it will appear like that: one album after another, sorted by filename in each folder.
In MusicBee, so far, I managed to group them by folder:
Or to sort them by filename:
But as you can see, none of these are doing the job.
Basically, when I group by folder, I can't get control over how it's sorted within these folders.
Am I missing something super obvious? xD
Thanks!
Last Edit: June 07, 2021, 07:10:10 PM by Ezhaac
Ezhaac
Yeah, that answer seems on point.
I feel like "MB IS NOT A FOLDER PLAYER" should be a sub-title to the forum at this point.  If you don't want to tag your files properly, then it will be A LOT of work to make MB show your files the way you want it to.  Seriously, if you don't want to maintain a library, MB is NOT THE RIGHT TOOL FOR WHAT YOU WANT TO DO.
