Author Topic: highlight and love columns overlap  (Read 2923 times)
chrctrlmt
In version 3.4.7805, displaying both the 'highlight' and 'love' columns in 'albums and tracks' view creates a visual artifact as seen on track 3 of the screenshot.  This only occurs when the track is not rated as 'loved' (when it is, the highlight isn't shown at all).  The skin I'm using is DarkGREEN from the Dark-Metro Series:
Last Edit: June 01, 2021, 12:10:34 AM by chrctrlmt
In 'set displayed fields' do you have 'highlight' set?
if not, right-click on any field in the header > set displayed fields . find 'highlight' in the left side > drag into position on the right side
chrctrlmt
Both love and highlight columns are set - that's why they are overlapping.  From what I understand if the highlight column isn't set, then it wouldn't display like in the screenshot.
Have you tried widening the column(s)? Either via 'auto-size all columns' or manually?
Have you tried dragging the highlight (or love) column to another location (to right right)?
The Incredible Boom Boom
I also see this, but I've never posted about it.
It happens when "compact grid" is selected.
Except the OP said they're in albums and tracks view.
chrctrlmt
The highlight or love column cannot be moved or widened, and there is no option to auto-size columns in this view.  To confirm what someone else said - it is while 'compact grid' is selected.  I am not in 'detailed list' of the 'albums and tracks' view.
Last Edit: June 01, 2021, 09:09:58 PM by chrctrlmt
Ahhh ... I understand now. Boom Boom said "compact grid" but my eyes and brain saw "compact view"
None of my suggestions are available in compact grid view.
Sorry for the confusion.
Last Edit: June 12, 2021, 12:40:00 PM by phred
Thats fixed for the next v3.4 patch update
Last Edit: June 12, 2021, 01:09:31 PM by Steven
