Author Topic: Creating a tab for a single folder of music  (Read 1055 times)
Kip
I have recently started using this app and there is something really bugging me. How do you set a tab to a single folder? I was able to do this on the first day I used the app, but forgot how and have never been able to replicate it. I do not believe I used playlists or different libraries, as they did not work when I recently tried it.
Screenshots -
1. "Shuffle" playlist connected to only one folder:
https://cdn.discordapp.com/attachments/833759708514746409/843592395241160754/unknown.png
2. Music tab connected to my library, which is both my "Shuffle" and "Save" folders:
https://cdn.discordapp.com/attachments/833759708514746409/843592265862742044/unknown.png
3. "Shuffle" is not connected to a playlist:
https://cdn.discordapp.com/attachments/833759708514746409/843593226740695110/unknown.png
I have another folder I would like to connect to a tab on the app, and so if anyone knows how to do this it would be much appreciated.
Kip
Thank you very much! I didn't use this method when making my shuffle one, but it works the exact same way!
