Author Topic: Nested Playlist (Playlist Folders) Syncing to iOS Devices  (Read 3976 times)
TTJJMB
Hi there,
Are Nested Playlist (Playlist Folders) Syncing to iOS Devices supported in MusicBee?
In iTunes you are able to organise playlists into folders in order to organise them better. When syncing to iOS devices it will then sync playlists in their folders onto your device.
On migrating to MusicBee my playlist folders don't seem to come across correctly and just the playlists within the folders appear instead (no folders). I've noticed there is a "Create Folder" option though that you can put playlists in however am unsure if this is the same thing and whether or not it actually syncs to the iOS device this way.
Thanks
