Author Topic: Help: Cannot play DSD  (Read 2438 times)
Newyouth
I have been using MusicBee for a long time and it has been smooth. This is already my favorite player. But since last week, my MusicBee has a problem that it cannot play DSD files.
Intel NUC
Windows 10 Pro
MusicBee 3.4.7764 P
DAC: Teac NT-505
In MusicBee's Preferences, my settings are as follows:
Player - Audio Player - Output: ASIO and Sound device: TEAC ASIO USB DRIVER
In this audio player configure:
When I am in the DSD file playback option:
1. Stream DSD data as PCM(DOP): My DAC display PCM 176.4k, and no sound is played. This is the method I used all the time, but I don't know why it is malfunctioning.
2, Convert to PCM: My DAC display PCM 88.2k, and no sound is played
3. Stream DSD data: My DAC display DSD 2.8M, but only rustling noise is played.
For this problem, I reinstalled Windows and replaced the USB cable of the DAC. In order to confirm that it is not the fault of the DAC, I used both Foobar and JRiver Media Center to play. The DAC can play normally or decode DSD normally.
please help me!
ma_t14
Do you have the file "bassdsd.dll" in your MusicBee installation directory?
You could try redownloading it from here: http://www.un4seen.com
Last Edit: April 19, 2021, 02:24:59 PM by ma_t14
Newyouth
Thank you at first.
I had bassdsd.dll in MusicBee folder, and I download the new bassdsd.dll in www.un4seen.com, but still can't play DSD files normally.
ma_t14
Newyouth
Did none of these previous threads help?
https://getmusicbee.com/forum/index.php?topic=34298.0
https://getmusicbee.com/forum/index.php?topic=4863.msg84962#msg84962
Thanks,
- I read this topic and I view MusicBee bassdsd.dll (2.4.1.2) and bassasio.dll (1.4.0.2) version looks correct...
- I also try DSD Transcoder, but when I choose DSD Transcoder and Output option choose my DAC (Teac NT-505), DAC does not work.
- I also reference this topic: "https://getmusicbee.com/forum/index.php?topic=4863.msg163641#msg163641", download the patch and copy to MusicBee folder overwrites the old files, but DAC still output white noise (Stream DSD data), when I choose Stream DSD data as PCM(DOP), DAC display PCM 176.4k.
I recalled the process of the problem:
- Before last week, MusicBee can output DSD normally and use “Stream DSD data as PCM(DOP)” mode
- I updated the new version of MusicBee (3.4.7764 P) this Sunday and I cannot play DSD. But I reverted to the previous version and still cannot play. Also tested the Windows Store version.
For this, I reinstalled Windows 10 Pro and all the drivers (including DAC). But it still cannot be resolved.
Please forgive my bad English.
