Author Topic: Making Album Playlist Real Track List Of Album.  (Read 575 times)
Jakanddaxter619
So I'm not sure if anyone has asked this but i wanna get my playlists from one computer to another but I can't change the letter of my drive so I just have to remake my playlists and I don't want to sort them in order again so I was wondering if there was any way to automatically to make them the real track list order. I'm new to having to do this so sorry if it's a stupid question.
ma_t14
Not sure if there's a way to do it from within MusicBee, can't check or recall at the moment but,
If you export the playlist you can then use a text editor to open the playlist file and change the drive letter using a simple find and replace.
Then import the playlist using File > Playlists > Import Playlists..
Last Edit: April 19, 2021, 11:47:13 AM by ma_t14
Jakanddaxter619
oh so I can just change it thanks that just saved me a ton of time
