Author Topic: Locate/Find missing files - make it scrollable.  (Read 2162 times)
yaccoff
The columns in the Locate Missing Files popup. Is it possible to make each column scrollable (left to right)
E.g. Originial Filename is a long path name (which I would like scrollable) + a file name (which I would also like scrollable).....
The window appears to be a fixed size or percentage of the screen. You cant maximise it and therefore to see all the info you need to resolve, I think its desireable to make each column scrollable.
