Author Topic: Can the MusicBee C# API be used within another program/application  (Read 7563 times)
livaed
I would like to use the C# API within another program of mine, specifically for adding files to my MusicBee library so I was wondering if this is possible. I have never worked with APIs in code nor do I have a complete understanding of how the MusicBee API works, if there is another way to add music to the library programmatically I'd love to know as well.
Thank you.
A musicbee plugin runs as a dll inside musicbee. You can communicate to the plugin from another application using sockets, windows messages or other windows technologies
livaed
Is this the best way to add music to my library or is there some way I can add files to the library from within my own code?
