Author Topic: v3.3.7491: track lyrics not shown as often as before (previous versions)  (Read 663 times)
davec
Hello, I have been using MusicBee for some time and think it's great!  I recently installed v3.3.7491 and I am finding that the track lyrics are not shown as frequently as before (my previous installed versions) in Theater Mode, and they're quite often relating to a different track.  Also the selection of gallery artist images is not as good as before.   Is there a setting somewhere that I should be using?  I have played with the auto-tagging preferences for lyrics but it doesn't seem to make any difference.
The Incredible Boom Boom
Hello, I have been using MusicBee for some time and think it's great!  I recently installed v3.3.7491 ... Also the selection of gallery artist images is not as good as before.   Is there a setting somewhere that I should be using?
I think @Steven has had to deprecate some of the previous artist image sources, due to issues. I too find the gallery images to be not as good as years past, but it can't be helped. Fortunately, you can add your own images and they will rotate, though it will take some elbow grease.
As far as the lyrics issue, first update your MusicBee to 3.4 (https://getmusicbee.com/forum/index.php?topic=32142.msg187516#new), then install the LyricsReloaded(updated) plugin (https://github.com/mbfrankz/LyricsReloaded/releases/tag/1.1.10) and select the lyrics sources in Prefs/Tags(2).
