Author Topic: Feature Request: Save Sort and Group setting PER Playlist (and not global)  (Read 1004 times)
pstein
Unfortunately when I change the sort order in one playlist it is automatically changed in all other playlist as well.
Same with grouping.
I would to have different sort orders and different groupings for different playlist.
Even a custom view does not store it.
So what is need are two new checkboxes in dialog pane for Playlist settings:
- Use current sort order as default for current playlist
- Use current grouping as default for current playlist
Alternatively a custom view should store these settings.
Can this be implemented?
Same with grouping.
A custom view should work but I recall there was a bug in older MB versions, so did you try using v3.4 which is available from the first forum topic
pstein
I am using v3.3.7491 Portable.
Its the newest I can get from webpage:
https://www.getmusicbee.com/downloads/
If a v3.4 exists: why is it not listed on the webpage mentioned above?
Because it's not an official release yet
