Author Topic: Visual Basic Form hangs using API 3.1  (Read 7050 times)
pixeltools
Hello all
I am trying to make a MusicBee Plugin that opens a window and writes the TrackChanges to that window.  This window will be  merged with a Zoom channel.
I easily made a simple MS Visual Basic Form and added a text box that gets written with the track name each TrackChanged notification. This works perfectly the first time the plug-in gets Enabled.  But restarting MusicBee causes the Form to be hung up … with the Window waiting circle.
I am using the Visual Basic plugin sample 3.1 into MusicBee 3.3.7491 P. Are these versions compatible?
I also built the C# Source 3.1.  This results in the error when enabled:
      Unable to initialize plugin: mb_TestCSharpDll.dll
      You need the latest version of MusicBee to use this plugin
I have spent quite a bit of time trying to get just a basic VB form to be fired off in one of the initialization routines .. but it always hangs on a relaunch of MusicBee. I've tried the VB and C# plugins with Visual Studio versions 2010 and 2019.
Any help will be appreciated.
Mark
All plugin versions will work with future MB versions.
You need to understand that plugin notifications are not done on the GUI thread, so when doing user interaction you need to invoke to the GUI thread.
use MB_GetWindowHandle() to get the musicbee window handle and then use Form.FromHandle(xxx) function to get the form object that you can use for invoking
pixeltools
Thank you for your prompt response!
Would you be kind enough to provide some more hints as how to connect our Form to the MusicBee plug-in thread?
Starting with the VB Source3.1 sample project,  I added a Form1 design with a text box.   I generate the form:
Dim oForm As Form1
oForm = New Form1()
oForm.Show()
In the ReceiveNotification routine, I write the current track name to the Form:
   Case NotificationType.TrackChanged
      Dim tracktitle As String = mbApiInterface.NowPlaying_GetFileTag (MetaDataType.TrackTitle)
      oForm.TextBox1.Text = tracktitle
Per your suggestion, I added
  Dim MBptr As IntPrt
  MBPtr = mbApiInterface.MB_GetWindowHandle()
It is not clear how your suggested function
 Form.FromHandle (MBPtr)
should invoke our Form1
Thanks so much for your advice
Mark
Dim MBptr As IntPtr
Dim f As Form = DirectCast(Form.FromHandle (MBPtr), Form)
f.Invoke(
    Sub()
         ' this code runs in the GUI thread
    End Sub)
pixeltools
Steve,
Thanks for your support. Your suggestions got my plug-in working properly.
In summary, for Forum Readers, my goal was to create a window that displays the current playing track name.
This window will get merged with a Zoom channel using OBS to automatically display the current track on our Zoom channel.
In the Visual Basic Source Plug-in 3.1, I created Form1 and added a TextBox1
At the top of the TestVbDll.vb file I declared oForm
    Dim oForm As Form1
In the Initialise Function I added code to create the form in the MusicBee GUI thread:
        Dim MBptr As IntPtr
        MBptr = mbApiInterface.MB_GetWindowHandle()
        Dim f As Form = DirectCast(Form.FromHandle(MBptr), Form)
        f.Invoke(
        Sub()
            f.Show()
            oForm = New Form1()
            oForm.Show()
        End Sub
and in the TrackChanged Notification I added code to write the current track to the text box
             Dim tracktitle As String = mbApiInterface.NowPlaying_GetFileTag(MetaDataType.TrackTitle)
