Author Topic: Biographies showing up in lyrics instead of lyrics  (Read 1135 times)
MADBIKER1960
  • Hello, I am a friendly knowledgeable guy.
Hello fellow MB users;
I have noticed with this new version of MB that the lyrics are not showing in the lyrics area, instead it shows the singers biography.
It is getting very irritating to have to go to the song and copy the lyrics and paste them in after deleting the biography out.
Can someone explain to me how to correct this or do the developers/programmers have to do the fix themselves.
Any response would be greatly appreciated. :)
If you're talking about the Now Playing window, drop its header bar menu and you'll see that the choices Main Panel (left side), Main panel (right side) and Right sidebar all have the option to show either Lyrics or Biography--be sure they are set to Lyrics.  These can also be set by choosing "Customize Panel" from the same menu as shown below:
MADBIKER1960
Thank you for the response.
I did include a screenshot, but I was not logged into the site to do so.
My bad.
