And thanks to that instruction I have now duplicated music files, ones are outside of the organized folder and others are inside it...
Isn't there any easy way to do that? I have the same problem every time I try to import anything.
[Edit] Ok, I think I get it... I should have these files on the same disk as a library before importing... Then MusicBee organizes it. If it's on other disk, I end up with files in 2 places.
