Author Topic: Enhanced Discord Presence  (Read 50092 times)
cleaninfla
This is the first plugin i wrote for MusicBee, It enables Discord Rich Presence and allows you to automatically upload and use your album artwork, Show time remaining, play / pause status, artist and track name.
https://github.com/maybeclean/musicbee-rich-presence
https://github.com/maybeclean/musicbee-rich-presence/releases/tag/v1.1
*Discord has a max size of 300 for assets meaning you can have 298 artworks including play / pause icons or 300 without. This is an internal limitation and cannot be bypassed.
**Characters from other languages (Japanese for example) might not pass Discord's asset regex and fail to upload artwork, currently looking for a work around.
***This plugin uses a publicly exposed portion of the Discord API (/assets) to upload images and does not violate any ToS or agreement because of that.
Last Edit: May 08, 2021, 08:11:56 PM by cleaninfla
mantecademani
Hey, just managed to get this plugin working for the most part, but I ran into one issue. I'm getting a ["String value did not match validation regex."] error in the log file whenever I play a song from the Owl City album "Maybe I'm Dreaming". Any idea what it could be. Not a huge deal, but would be nice to figure out. Awesome job with the plugin though, really nice to have the album art in discord!
🎶 "Reality is a lovely place, but I wouldn't want to live there."
Last.fm: https://www.last.fm/user/mantecademani
cleaninfla
That issue is because of Discord's internal regex not allowing some symbols, i've updated the repo so single and double quotes are changed to '_' which Discord supports and that should fix your issue.
mantecademani
That seems to have done it, thanks!
cleaninfla
Precompiled Binaries are now available at GitHub with full functionality https://github.com/maybeclean/musicbee-rich-presence/releases/tag/v1.0
Last Edit: April 30, 2021, 11:50:42 PM by cleaninfla
kick12134
Hey there, I tried this plugin but when I tried to activate it in musicbee it gives me an "Unable to initialise plugin: mb_discordrichpresence.dll" error
cleaninfla
This has been fixed with the latest commit, binaries have been updated aswell. Feel free to redownload them and try it out.
HOX
cleaninfla
Plugin should work fine with portable, only difference is that you would drag the plugin files to the plugin folder in your portable folder. Everything else is the exact same following the readme.
Shingo
Hey, I downloaded the latest binaries (v1.1) and followed the instructions in the readme, but I still get the same error as kick12134.
My MusicBee version is 3.4.7792.
diozzz
Hello, I tried to enable the plugin but it gives me an "Exception has been thrown by the target of an invocation" error message.
Also, Here is the error logs.
2021/05/11 0:10:30 - 10.0.19042.0 - 3.4.7764.37422D - System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.FormatException: The format of value '' is invalid.
   at System.Net.Http.Headers.HttpHeaderParser.ParseValue(String value, Object storeValue, Int32& index)
   at System.Net.Http.Headers.HttpHeaders.ParseAndAddValue(String name, HeaderStoreItemInfo info, String value)
   at System.Net.Http.Headers.HttpHeaders.Add(String name, String value)
   at MusicBeePlugin.Plugin.Initialise(IntPtr apiInterfacePtr)
   at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters)
   at #=z_aDAVc7sMkwkYxQETg==..ctor(#=zoKrwgApZgrrQua03HQ== #=zmYRlZmg=)
sadpengu
Have the same issue as above!
 Looking forward to a fix :)
chiascuro
I'm sure you can get around the 300 image restriction if it was possible to use multiple developer applications, after all you can have over 20 developer applications on one Discord account alone.
To fix the issue with foreign characters not being accepted by Discord's asset regex and fail to upload, you could instead create a database and assign each album a string of numbers(+letters) instead of the actual name for assets (this would also be beneficial for albums from separate artists that by chance have the same album name).
Otherwise great plugin and when those 2 things get fixed/added it's gonna be perfect! Thank you for your efforts
pachi_87
so my player is showing weird characters next to the track and artist tags
Last Edit: June 21, 2021, 05:44:47 AM by pachi_87
draykid
Do you know why I get an error "Failed to find .LDB files to obtain Auth Token" when I try to add the plugin?
