I'm not 100% sure how to replicate this bug, but it appears to happen when I'm using Music Explorer to listen to an artist, then go back to my main library view and press "Play Library Shuffled." I
think I need to listen to some music for a while before going back to full library shuffle for this error to appear. As I said, I can't replicate it consistently, but it
seems to happen when I do the steps described above.
Using MB 3.4.7688 on W7 x64
MusicBee v3.4.7688.39513D (Win6.1), 27 Jan 2021 17:31:
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at #=zJ1UKZWXcXYrcaOWjhkddve8g6Db0TU7jpQ==.#=z3ZfvupfvVUN3rewRRQ==()
at #=zlJnguFcLToaH8zC8e8T9yP8=.#=zkeg3HzU9g3li(IList`1 #=z4KAJeSI=, #=zXDVoo8kht3J7qWX9f3b8KfQ= #=zW9XQKk4=, String #=z9fEj38o=)
at #=zlJnguFcLToaH8zC8e8T9yP8=.#=z3BkhTWyMjrJr(IList`1 #=z2lnINYo=, #=zXDVoo8kht3J7qWX9f3b8KfQ= #=zW9XQKk4=)
at #=zlJnguFcLToaH8zC8e8T9yP8=.#=z$Rel456cDme6$hPmp8d6mQs=(List`1 #=z2lnINYo=, #=zIsMyI0kmauSIcF0v$343tTw= #=z4BaPkH8=, #=zXDVoo8kht3J7qWX9f3b8KfQ= #=zW9XQKk4=)
at #=zlJnguFcLToaH8zC8e8T9yP8=.#=ziBko$qQVvw9PwMx2sg==(#=zj5O3qpfStX51ElIe9dRUtda7EV5e #=zprRk74qFCd3X)
at #=zJ7lFJzydtZwZNSaLBfRCi9EutUqf.#=zy8Oc5tI=.#=z0ILMT2E=(ApplicationCommand #=zYPDjVpU=, Object #=zG_8AS2I=, IList`1 #=z2lnINYo=)
at #=zu18l$Q_CZiqSQDtULvKPBBo=.OnClick(EventArgs #=zKPKQElo=)
