Author Topic: Sync not working correctly with my Samsung Note 20 Ultra (playlists)  (Read 3448 times)
smellhole
Hello!  First of all:
1. I've looked here already: http://musicbee.wikia.com/wiki/Devices.
2. I've manually searched the Portable Devices sub-forum back to Jan 2020.
3. I did an automated search and found this: https://getmusicbee.com/forum/index.php?topic=22995.0 (which didn't help).
Alas, I still can't get it to work.
Here's the deal: I just want to sync four playlists to the phone. At first I checked the Devices section of preference and found two list items for my phone. I selected the first one and tried to sync but it didn't work. I assumed that entry was bad so I deleted it and tried the second one. That didn't work either.
 Here's how I now have it setup:
And...
I also tried this:
MusicBee can see my phone:
I tried the File menu sync, but that didn't work. I next tried to sync an individual playlist.
At this point it's clear that either there's some technical problem, I'm doing something wrong and/or I'm missing something plainly obvious.
Last Edit: January 22, 2021, 08:50:56 PM by smellhole
smellhole
After over an hour later of doing other stuff on the computer, I got this error.
How was MB installed? (Installer, Portable, Store)
Is there anything in the Error Log from the time this happened? Help > Support > View Error Log
smellhole
Version: 3.3.7491
Installer (downloaded from musicbee site)
Log Stuff:
There's a ton of stuff in the logs, but there's basically just two types of entries for today.
1/22/2021 2:00:33 PM - WPD:The library, drive, or media pool is empty. (Exception from HRESULT: 0x800710D2)
1/22/2021 2:37:31 PM - Copy C:\Users\shane\Music\Van Halen\2012 - A Different Kind of Truth\11 - Van Halen - A Different Kind of Truth - Stay Frosty.mp3 to SM-N986U\Phone\Music\Van Halen\A Different Kind of Truth\11 - Stay Frosty.mp3
1/22/2021 2:37:31 PM - The requested value cannot be determined. (Exception from HRESULT: 0x802A0006)
Thanks!
I wont be able to help with these errors and I suggest you try another application for syncing purposes
smellhole
Alas and woe. I'll have to go back to MediaMonkey then. And I was really digging MusicBee  :'(
You could try the Wifi Sync android app
Doesn't one need to have one successful preview or sync before the WiFi app will sync?
Thats what I say to keep the message simple but it depends how far in the process it gets
