Hello hai.
Another random idea, since playlists are a strong point in MB, but the management/overview aspect could potentially be enhanced (just a wish for the wishlist, as I find myself struggling with the playlists settings regularly, that are often hard to set, lock & check)
As a picture says a thousand words, there's one below, and this should be pretty self explanatory. Although the "..." might need an explanation...which I could imagine could be useful to:
- in the top row, give options for which / and how many of the playlist/autoplaylist settings to show in a visual way, i.e. in the mockup, Lock and Sorting would be set to show as columns.
- whereas the '...' in each row next to a playlist, one would have access to all of the playlists settings in a drop down menu, and be able to switch them right there
Maybe others and Steven might find this wish-for and pursue-worthy, and hopefully not too hard to implement - alas, I have a hunch, this would/could be. (then again, I was thinking something like the Hierarchy explorer would take weeks to months to implement as well...
Mockup with non fitting, random icons.... happy to do some proper ones, if wanted
Cheers.
c.
