Author Topic: Reset Plays not working  (Read 804 times)
DuVtrell
When I reset plays it initially works but when closing out and starting up musicbee the plays reset instead of staying at zero.
Select all---reset plays
fairly straightforward but it's not working for me.
How was MB installed? (Installer, Portable, Store)
Make sure you have read/write permission in the directory where MB is installed.
Try launching MB as administrator.
DuVtrell
Version 3.3.7491
I used the standard installer. Tried running as administrator but the issues persists. Maybe I should uninstall and start fresh?
I would suggest the Portable version. And put it in a non-Windows controlled directory. Such as x:\MusicBee. You can get 3.4 from the first forum topic.
Last Edit: January 19, 2021, 09:48:05 PM by phred
Trying now its working fine for me, so try updating to v3.4 as phred suggests
DuVtrell
Always like those nice and simple fixes. Thanks for the feedback.
