Author Topic: customized field for a song in playlist  (Read 843 times)
Doron Zur
What I'm looking for is a customized filed which will be attached to a song in a playlist, and will be saved with the playlist. The same song can appear in different playlists but in each playlist the field will have different content.
Is it possible?
Thanks
The Incredible Boom Boom
You could save the playlist name into an unused tag, then use the $IsNull() function inside a Virtual Tag to achieve your desired result.
I don't think that'll work, because there's no way for a tag to know what playlist you're viewing the track in.
