Author Topic: Name of skin  (Read 1830 times)
user73
I wanted to ask this for quite long as feature request just couldn't because of this or that reason.Anyhow i think if we could get to know the name of skin either in menu or wherever Admin feels right then it would be so helpful.we have so many skins and some we like some we don't.
thx in advance.
The name of the current skin is shown as selected in the "View" menu under "Skins."
user73
it is ticked if we choose certain skin manually .
Beauty of Mb is that it has so many skins..so i choose option of random skin.
So MB loads any skin from different categories and then it's hard to know which skin is loaded.
wobbly
maybe Steven could put  the name  of the skin currently loaded  at the top of the  skins menu   "Current Skin :  Skin Name"
  • MB Version: 3.6.9255 P
@ user73
What version are you using?
When using Random skin setting, it should display under View> Skins> Random Skin
user73
im just updated to version 3.4.7688
yes it do shows right now.Strange i never noticed that before..any idea since when does it start showing like that.Its vaguely visible ,so
still i hope in future maybe it is more visible,we have status bar which is almost empty.
thx for helping.
Last Edit: January 19, 2021, 11:30:04 AM by user73
